configure isis import-policy
configure isis import-policy [policy-map | none]
Description
This command applies a policy map for routes imported to the FIB from all IS-IS router processes on this virtual router.
Syntax Description
policy-map Specifies the policy to apply.
none Removes any policies assigned to this virtual router.
Default
None.
Usage Guidelines
IS-IS policy files support the following policy match conditions:
  • nlri IPv4-address/mask-len IPv6-address/mask-len
  • route-origin [isis-level-1 | isis-level-2 | isis-level-1-external | isis-level-2-external]
IS-IS policy files support the following policy action statements:
  • cost
The following command applies the IS-IS policy policy2 to the virtual router:
configure isis import-policy policy2
Platform Availability
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
